CPU + Mobo Upgrade
23 Sep 2005
Fife
I'm currently running
Gigabyte GA-X58A-UD3R Mobo
i7 920 CPU
Corsair XMS3 6GB (1600Mhz) RAM
I've also got an overclocked 3GB 7950 which I'm quite happy with.
Would it be worth upgrading my CPU and mobo? Could I do anything worthwhile for about £200? Play BF4, ARMA3 etc. Have OC the CPU but been having a lot of stability issues, and the lack of full SATA3 on the mobo is holding my SSD back a lot.
I swear that was priced at £224 when I was in the shopping cart.
I would advise keeping that MOBO and having a look at the other i5's.
You should get at least a boost in FPS etc from running the z97 chipset.
OK - I've got a bit more cash to play with. What would be a worthwhile upgrade from a i7 920 for £350? (partnered with an OC 7950).
I need CPU, RAM & Mobo.
Hi, they have many bundles available, take a careful look around the site.
Here is one to consider:- http://www.overclockers.co.uk/showproduct.php?prodid=BU-006-MS&groupid=2833&catid=2836&subcat=2861
It is not the latest unlocked i5 but is unlocked.
If you go AMD, just make sure you go for a good Motherboard, this is a good starting point as it has very good 8+2 phase CPU VRM power handling which is needed for overclocking the 8 core AMD CPU's. http://www.overclockers.co.uk/showproduct.php?prodid=MB-471-GI&groupid=701&catid=1903&subcat=2046
So you could get this for £350:-
CPU £140 http://www.overclockers.co.uk/showproduct.php?prodid=CP-382-AM&groupid=701&catid=1967&subcat=1825
Motherboard £72 Or £103 http://www.overclockers.co.uk/showproduct.php?prodid=MB-471-GI&groupid=701&catid=1903&subcat=2046 (as a starting point, could go with this instead) http://www.overclockers.co.uk/showproduct.php?prodid=MB-559-AS&groupid=701&catid=1903&subcat=2046
Ram £66 http://www.overclockers.co.uk/showproduct.php?prodid=MY-035-TG&groupid=701&catid=8&subcat=1387
Cooler £28 http://www.overclockers.co.uk/showproduct.php?prodid=HS-007-RT&groupid=701&catid=2330&subcat=2666
So from approx £306 to £337 +Shipping.
YOUR BASKET
1 x Intel Core i5-4690K 3.50GHz (Devil's Canyon) Socket LGA1150 Processor - Retail £179.99
1 x Gigabyte G1.Sniper Z97 Intel Z97 (Socket 1150) DDR3 ATX Motherboard £124.99
1 x TeamGroup Vulcan RED 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLRED38G2400HC11CDC01) £59.99
Total : £374.57 (includes shipping : £8.00).
Plenty of boards and ram to pick from, the Sniper has a good onboard sound via a Creative Core3D chip.
Thanks for that. What is a decent cooler for that setup?
