CPU monitoring overlay
6 Jan 2013
Yorkshire
Hello, just wondering is anyone could suggest a Afterburner like monitoring overlay but for the CPU rather than GPU. Or maybe there is some way to add CPU sensors into AB monitor.
Cheers.
AB should have the option, well it does for me anyway. Each core with load and temps (HT cores included)
In the monitor tab you will need to make sure they are big ticked on the left hand side if you scroll down, and also tick the on-screen option just underneath that section. Frame rate and frame time are often disabled too, so I would suggest enabling them as well.
Yeah, ive got them on, im more interested in core speeds and voltages though an theres no options for them.
You could try HWiNFO66 + RivaTuner?
This is what I use, works very well as you can chose whatever sensor you like.
I have CPU Core Clock, Thread Usage, Temp and VCORE.
