CPU OC HELP
13 Jul 2019
I new to the overclocking scene, I have watched some YouTube vids and google things but still kind of stuck would like to know the values roughly for the manual PBO.
TDC:
PPT:
EDC:
Precision Boost Pverdrive Scalar: Auto
Max CPU Boost Clock Override: 200MHZ
Motherboard: Gigabyte X570 AORUS ELITE ATX AM4 Motherboard
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core Processor
Ram: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory
PSU: Corsair HX1200 Platinum 1200 W 80+ Platinum Certified Fully Modular ATX Power Supply
Things I have configured:
Cool & Quite@ Disabled
SVM: Disabled
C-States: Disabled.
SMT: Disabled
Above 4G Support: Enabled
HPET: Disabled right now.
Kind regards.
Not sure about 3000 series Ryzen processors but you could try a negative voltage offset.
Start with -0.01v value and increase from there and back off when you get instability.
There are many factors in overclocking including silicon quality so you’ll need to carry on reading OC guides and figuring out what your system can do.
I know that dual rank RAM helped Ryzen performance a lot. You’ll not likely be able to find dual rank RAM anymore but you can get close by using 4 RAM DIMM modules.
Forget curve for a 3900x, you'll get much better results with an all core overclock
TDC:
PPT:
EDC:
SVM: Disabled
C-States: Disabled.
SMT: Disabled
Kind regards.
