CPU OSD Info
30 Nov 2007
Is there a work around to get a OSD plugin for afterburner to display CPU temps and usage as well as GPU info ?
Or
Is there anything that I can use to display CPU info OSD with AB also running OSD ?
I think its possible to run HWMonitor or Openmonitor, but you must use Core-Temp for them to work, if you want just basic CPU info use Core-Temp + their CPU Gadget use link to Core Temp, l use it, CPU clock, temps + memory usage, its a handy gadget. ;)
http://www.alcpu.com/CoreTemp/
Thanks for info mate
I'm after something along the lines of osd like you see in games on top of screen
