Hi,
I've not been here for a few year (got married) but used to post quite a lot. Not sure if anyone remembers me. Any I have an overheating problem.
I'm trying to decide on which new components I need to buy to fix it The specification is:
Windows 7
Athlon 64 X2 6000+
Gigiabyte S-Series GA-MA770-DS3/S3 rev 2 motherboard
4 gb DDR memory (corsair but can't remember exact spec)
1 tb samsung hdd, blu ray player
Geforce 9800 GT (BFG)
The CPU is overheating and the computer is shutting down automatically mainly when playing YouTube videos (CPU is at about 25% in these cases) but not when playing full HD videos in VLC media player (when it is at 40-50% load and doesn't get much hotter). It's also often shutting down when installing software (doing lots of disk accessing) and when I tried to play Skyrim.
I set the bios to give an audible warning when the CPU temp reached 70c and its definately a CPU overheating problem because it starts giving the warning intermitently and then constant and then shuts down. The heatsink on the CPU is too hot to touch with my fingers at this time. The rest of inside of the case is cool and the same with the side off.
The heatsink and fan is something I got from PC World after I started having problems like this with the stock cooler. I can't remember what the make and model was but I thought it would do the job because I am not overclocking and the rest of the case is cool. One weird thing is that the part of this heatsink base which makes contact with the CPU die does not completely cover it. I thought this was extremely odd (said it supported socket AM2 and AM2+) but it did perform better than the stock cooler for a while and I had temps of about 40% idle and no shutting down. I am assuming that because the heatsink is red hot (fan is running) that heat transfer is not a problem so I am assuming its a problem with the CPU, motherboard or PSU. I just don't know what to replace. Does anyone have any advice?
Regards,
Dave WP
Windows 7
Athlon 64 X2 6000+
Regards,
Dave WP
