 - 6 Jun 2004
 - Gloucester
Hi I have an E6750 CPU running at stock speeds with the stock Intel cooler. I also have the side of my case off due to installing my old TV card.
Anyway the CPU appears to be overheating, I know this due to the beeps from the mainboard (Gigabyte GA-G33M-DS2R). i then checked the temp in the BIOS and it was around 85 degrees and creeped up to 91 whilst I was just watching it!!
When the beeping noises were going on the fan on the heatsink was not spinning as it was not under load.
Does anyone have any ideas, i appreciate I'll probably get comments like get a new cooler but I shouldn't have to as I am not overclocking and the machine is not being used in a particularly hot environment.
Also would it help if there was some way that the fan could be made to constantly spin instead of now and again?
Thanks
AFF
Thanks
AFF
