- 24 Mar 2014
- Inverness,
I am not sure if this should be in watercooling considering the fact that I now have a closed loop attached to my CPU but here goes, also I don't mind if this gets moved
I have been having a long term issue with my
FX8150 ( I will get more specs up after I get home)
it seems it likes to over heat when playing certain games, these games are ofcourse some CPU intensive titles such as Guildwars 2 etc.
so heres my question,
since I am overheating, even after setting the cpu voltage in windows to 80%, which used to work in the air cooled setup I used to have (barely) now that I have a closed system, I am getting random shutdowns, which I can only explain as an overheat. The shutdowns are instant and I can switch the machine back on straight away.
I have a feeling I just need to top up the water cooling system, which I will try later in the future when I have the funds to get, at the very least, some kind of funnel/ killcoil to get the fluid in their. But ncase that doesn't work, I thought I would have this post up so I can get some advice, any other diagnostics/ suggestions would also be appreciated also.
also: I can tell its overheating as the coolant liquid is quite warm when I touch the tubes, also I have two outwatd facing fans on the radiator. ( the 2nd was an attempt to fix the over heat issue)
As I have stated earlier - more specs and possibly some photos are coming later as I am at work now so can add everything.
