Hiya,
A friend of mine has a Ryzen 2700X that is trying to melt itself. It was reaching temps close to 100'c just idling on the desktop, and even stuff as simple as opening Discord would lead to the system shutting down for temperatures.
We reseated and replaced the thermal paste on the cooler (an older Corsair AIO) and cleared any dust buildup. Its now achieving temps of 85'c in BIOS and that rises to 90'c+ after ten mins or so, which is still ridiculous.
We can now get it loaded into Windows and it will idle. CPU usage doesn't exceed 7% on idling, so doesn't appear to he any issues there. Temps on desktop are the same as in the BIOS. We've looked at the fan profile in BIOS and its set to max, its spinning at 1800rpm (its max) basically from start-up. All other temps are normal, other system and case fans are idling and they're all below 35'c.
Any other potential causes to investigate? Does it just sound like a bad chip?
If its a bad chip the current plan is to stick a 5600G in there and limp the system through for another year or two before he goes all in on a new PC.
Full specs:-
Ryzen 7 2700X (base clock)
Gigabyte B450 Aorus Elite
32GB Corsair Vengeance DDR4, 3200MHz, CAS16
MSI RTX2070
Seasonic 650W 80+ Platinum
Thank you!
Full specs:-
MSI RTX2070
Thank you!
), but will check how his hoses are routed anyway as that's a good point.
