I have been trying for ages to fine tune my 4.2 Ghz I7 930 overclock on a gigabyte x58a-ud3r rev 1 board with f5 BIOS 12 GB Corsair 1600 RAM
I may have a naff chip but i cannot get it stable under 1.392 V showing in cpu-z, I have tried with and without LLC but it seems 1.392 v is the cut off point.
Temps are acceptable at max 85 C with an Noctua D14 in Prime and rarely hit a max of 83 when rendering 3d stuff, but it is a bit high for my liking
I have been toying with voltages to see what i can get away with and it seems that on i have to set qpi-vtt to 1.355 and all other voltages on auto to see what the MB does with them. The only change it makes is to push the IOH core to 1.16
Now here is the odd part, i decided on a whim to lower my CPU PLL, drastically, in fact it is at 1.30 ( default 1.80) and i seem to have no adverse effects at all, prime stable
Does anyone know what is the deal with cpu pll as most say to raise it for stability and does anyone have any suggestions of how i can manipulate other settings to allow for a lower vcore ( 1.44375 in BIOS with LLC Level 1 gives me 1.392 under load)
