Hi,
I've had the machine in my sig for a while now, it was bought second hand for a very reasonable price, but when in the new case, the PSU wire to the CPU was too short - so I bought a £1.62 extension off eBay.
A few months back I had a look in HWMonitor, and it said my 12V rail was stuck at 13.44V, so I ran Prime95 to check with a multimeter - voltages were fine (12.05V) but there was a burning smell I couldn't locate properly. I left that down to dust on the cheap (read - OEM ****) RAM that gets reasonably hot. I cleaned the RAM and left it alone.
It's been working fine for a while now, but today I was rendering some videos / playing BF3 and the burning smell returned, this time with some electrical crackle !
I turned off the PC as anyone would, and opened it to find smouldering plastic on one of the extension wires.
I doubt it's damaged anything, unless the electrical crackle was shorting and damaged the PSU - I don't know.
Now, I can either buy another extension from a more reputable seller, or upgrade the PSU from the (again OEM) Lite-ON 450W thing that's currently in use.
I was thinking about an OCZ ZT 750W PSU as it's a pain changing the PSU in the Powermac case and wanted something I could use for years, possibly adding dual cpu, sli etc etc ...
http://www.ocztechnology.com/ocz-zt-series-550w-750w-power-supply.html
Any recommendations for PSU / what to do ?
Pics of the burn
I turned off the PC as anyone would, and opened it to find smouldering plastic on one of the extension wires. I doubt it's damaged anything, unless the electrical crackle was shorting and damaged the PSU - I don't know.
Pics of the burn
no experience of them,but I would trust a well known branded make like OCZ,Corsair, Antec, etc first.
