Cpu power
10 Apr 2014
Hampshire
Im wiring up my new build atm and dont know which port on my psu the connector goes in. Is it 12v1/2 or 12v3?
The cpu is a socket 1150 , psu is an antec 750w and mobo is an asus z97m plus.
Looking through Antecs PSU range they seem to only have one connector for CPU power which is 8 pin which splits in half.
Can you take a photo of the leads?
I actually have it all wired up now, im playing mass effect andromeda. The only other problem i have ran into is that there is a metallic smell coming from around the cpu area itself.
It may be just certain areas warming up, if your not getting any stability issues and your temps look fine I would not worry*
* Keep a look out just in case ;)
