- 5 Sep 2009
Hi folks
I just recently bought the Titan Sabre from OC.uk. It runs really smoothly and seems to be a really nice pc. However, I've been running AMD Overdrive so that I can see the temperatures inside my machine. I havent altered any settings or changed any BIOS. The pc is exactly as it was upon arrival.
My problem(?) is that the CPU temperature is shown to be 55-65c at idle, and after playing games for more than 5 mins, the temperature of the CPU rises to 80-95c. Now, I'm not particularly computer savvy, I dont know if that is normal, or safely within normal parameters, but my gut is telling me that those temps if accurate are too high.
If any of you could provide any advise as to how to make sure that those readings are correct, or how to make the cpu run a little more cooler, or even just let me know if those temps are ok, it would be greatly appreciated.
Thanks in advance.
Thanks in advance.
