CPU ratio keeps bouncing around
20 Mar 2004
Just did a format and reinstall on my computer, no real reason other then it's been about a year and a 1/2 since I've done it.
Decided to update the BIOS while I was at it and lost my overclocking settings while I was at it.
I wrote down my settings and put them back in, but I've noticed something wierd in CPU-Z, my CPU ration keeps changing. It changes from 12, the default to 21, which is what I set it to. If I go into the BIOS, the settings is 21. I've also noticed it's hit a few other ratios in between as well.
My Motherboard is a Asus P6X58D-E, the processor is a i7 930, 2.8Ghz.
Before the BIOS update, I had it overclocked at 4Ghz with no problems.
disable c1e and eist in the bios
why idk,i always used power saving with my oc it improved idle temps but that's for another thread
