- 13 Sep 2006
- running from 8igdave
I have OCed my q6600 to 400X8 in the BIOS this is what is read under load by CPU-Z. But 3dMark, coretemp, speedfan DXDIAG and most programs (even vista itself) reads it as 3.6 insted of 3.2 (coretemp tells me its 450X8). I have the Vcore @ 1.4V and have added minimum +v to northbridege and FSB.
could my MB be adding these 50Mhz to the FSB? IDK
Also i used expertool to take my OcUK 8800 GTX to BFG OC/OC2 levals
i have it clocked to 615/1900. Idel its about 64 degrees. after running 3dmark06 (all the tests it has on it) over and over again a few times The max temp i got the GTX too is 75. Is that good? normal? bad?
(FYI the 3dmark results were all about 12700 CLICKY IF IT WILL HELP)
what are the temps for a GTX on load an idle?
TIA
TIA
