Hi there.
I previously bought my current computer from OC at the beginning of the year. I've now decided its time to upgrade my CPU and maybe other parts of my system if need be.
I'm mainly using it for gaming therefore it's focusing on that perspective.
Below is my current spec etc. so you can base it around that.
CPU: Intel Pentium Dual-Core E2180 "LGA775 Core 2" 2.00GHz (800FSB)
MB: Abit IP35 (Socket 775) PCI-Express DDR2 Motherboard
GPU: Leadtek GeForce 8800 GT 512MB GDDR3 HDTV/Dual DVI (PCI-Express)
RAM: GeIL 2GB (2x1GB) PC2-6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit x2
Hard Drive: Seagate Barracuda 7200.10 250GB SATA-II 16MB Cache
PSU: Corsair HX 520W ATX2.2 Modular SLI Compliant PSU
PSU-Cooler: Arctic Cooling Freezer 7 Pro CPU Cooler
Case: Lian-Li PC-7A PLUS II Aluminium Midi-Tower Case
Monitor: LG L204WS 20" Widescreen LCD Monitor
What I'm looking for is a new CPU, I've browsed the shop and I just can't determine what to get. My budget is around £100-150 for the CPU alone and more if I require additional upgrades to my system e.g. memory, motherboard, GPU etc.
Also I have a vent (a fan attachment palce or whatever
) on the top of my case as was wondering what fan would be best suiting there?
Anyways thats it, I hope you can help me with this and hope to hear from you soon in regards to what I should get.
Thanks
Thanks
