Ran it for 10 mins:
CPUID HWMonitor Report
Binaries
HWMonitor version 1.2.1.0
Monitoring
Mainboard Model Z77 Pro4 (0x0000024D - 0x00B1DDC6)
LPCIO
LPCIO Vendor Nuvoton
LPCIO Model NCT6776
LPCIO Vendor ID 0x5CA3
LPCIO Chip ID 0xC3
LPCIO Revision ID 0x33
Config Mode I/O address 0x2E
Config Mode LDN 0xB
Config Mode registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 FF FF 00 FF FF FF FF 0B FF FF FF FF FF FF FF FF
10 FF FF FF FF FF FF FF FF FF FF F8 0E 00 00 FF FF
20 C3 33 FF 00 5C 00 00 C0 00 FF 62 00 80 00 00 01
30 E1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
40 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
50 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
60 02 90 00 00 FF FF FF FF FF FF FF FF FF FF FF FF
70 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Register space LPC, base address = 0x0290
Hardware Monitors
Hardware monitor Nuvoton NCT6776
Voltage 0 1.03 Volts [0x81] (CPU VCORE)
Voltage 1 1.88 Volts [0xEB] (VIN1)
Voltage 2 3.39 Volts [0xD4] (AVCC)
Voltage 3 3.39 Volts [0xD4] (3VCC)
Voltage 4 0.42 Volts [0x35] (VIN4)
Voltage 5 1.69 Volts [0xD3] (VIN5)
Voltage 6 0.79 Volts [0x63] (VIN6)
Temperature 0 24°C (75°F) [0x18] (SYSTIN)
Temperature 1 28°C (82°F) [0x38] (CPUTIN)
Temperature 2 47°C (116°F) [0x5E] (AUXTIN)
Temperature 3 44°C (111°F) [0x2C] (TMPIN3)
Temperature 4 65°C (148°F) [0x81] (TMPIN4)
Fan 0 1088 RPM [0x440] (SYSFANIN)
Fan 1 995 RPM [0x3E3] (CPUFANIN)
Fan 2 1174 RPM [0x496] (AUXFANIN0)
Fan 3 0 RPM [0x0] (AUXFANIN1)
Fan 4 0 RPM [0x0] (AUXFANIN2)
00 04 50 04 75 00 FF FF FF FF FF FF FF FF FF FF FF
10 04 73 00 00 00 00 FF FF 40 00 00 00 00 87 00 00
20 81 EB D4 D4 33 D3 63 18 FF FF FF DA 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF FF
40 03 00 50 FF FF 00 3F FF 2D FF FF FF 18 05 00 A3
50 FF FF FF FF FF FF FF FF C1 FF FF FF FF 00 00 FF
60 00 FF FF FF FF 01 00 FF FF FF FF FF FF FF FF FF
70 00 0A 00 2C 80 2C 80 2F 00 FF FF FF FF FF FF FF
80 FF 03 1F 0F FF 3C 3C 3C 00 00 00 00 00 00 00 00
90 0A 00 00 00 00 0A 0A 0A 0A AA EF 80 FF 40 46 C4
A0 0E 01 00 00 FF 00 00 FF 00 00 80 66 66 06 01 01
B0 00 00 00 00 00 00 28 00 1C 00 00 34 28 80 C4 FF
C0 01 00 00 00 00 00 00 00 00 0D 07 FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Processors
Number of processors 1
Number of threads 4
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 2
-- Core 2
-- Thread 0 4
-- Core 3
-- Thread 0 6
Timers
ACPI timer 3.580 MHz
HPET timer 14.318 MHz
Perf timer 3.320 MHz
Sys timer 1.000 KHz
Processors Information
Processor 1 ID = 0
Number of cores 4 (max 8)
Number of threads 4 (max 16)
Name Intel Core i5 3570K
Codename Ivy Bridge
Specification Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
Package (platform ID) Socket 1155 LGA (0x1)
CPUID 6.A.9
Extended CPUID 6.3A
Core Stepping E1
Technology 22 nm
TDP Limit 77 Watts
Core Speed 3600.5 MHz
Multiplier x FSB 36.0 x 100.0 MHz
Stock frequency 3400 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
L3 cache 6 MBytes, 12-way set associative, 64-byte line size
FID/VID Control yes
Turbo Mode supported, enabled
Max non-turbo ratio 34x
Max turbo ratio 36x
Max efficiency ratio 16x
Min Power 60 Watts
O/C bins unlimited
Ratio 1 core 36x
Ratio 2 cores 36x
Ratio 3 cores 36x
Ratio 4 cores 36x
TSC 3400.5 MHz
APERF 3600.6 MHz
