Hi,
I just moved my system into a smaller case so it will fit under my computer desk as the other case was too big. I ran HWMonitor to keep an eye on the temps and noticed my CPU temperature was quite high, especially when running games.
It seems to idle at around 50c, using the internet/Adobe photoshop etc it goes up to about 75-80c and playing games it gets up to 99-100c. This seems very high. I have put an extra fan in the back (Zalman 80mm) but this doesn't seem to have made any difference.
As far as Im aware it was running this hot before I changed cases. The cpu cooler has been removed a couple of times in the past to clean dust from it. I did this again but it was fairly clean. I've ordered some of this Akasa thermal compound & cleaner for it.
Any other suggestions. Has a 120mm fan in front, 80mm fan in rear and cpu has the stock cooler. Nothing has been clocked.
OcUK Flamingo FM-12A Midi Tower Case
Asus P5Q Pro Intel P45 (Socket 775) PCI-Express DDR2 Motherboard
OCZ StealthXStream 600w
Core 2 Duo E8400 LGA775 3.00GHz
4gb ram
Asus ATI Radeon HD 4870 Glaciator+ 1024MB GDDR5 PCI-Express
4gb ram
