5 Mar 2008 at 14:54 #1 Abz Abz Associate Joined 27 Jul 2004 Posts 678 Location London If the pins on the cpu slot are damaged in the motherboard, will this void the garantee. The mobo is still under 1 years. Can I still get a replacement?
5 Mar 2008 at 18:35 #2 BUFF BUFF Soldato Joined 23 May 2006 Posts 2,883 Location Glasgow if it's an LGA 775 mobo then generally socket damage isn't covered by warranty.
5 Mar 2008 at 18:55 #3 Smirnoff Smirnoff Permabanned Joined 18 Oct 2002 Posts 923 Warrenty is totally void when pins are bent, any physical damage to the board will also void the warranty.
5 Mar 2008 at 19:52 #4 crazyDAJT crazyDAJT Associate Joined 20 Jun 2007 Posts 1,641 Location Nottingham I think there are some pin straighting services some manufactures offer, i have heard it mentioned on the forums, but seen no links
5 Mar 2008 at 20:09 #5 Kanifee Kanifee Soldato Joined 13 May 2007 Posts 7,004 Location On the wagon, sorta ive straightend LGA775 pins before, not a hrd feet to do aslong as you have a steady hand and a little common sence.
