cpu temp 54c?
10 Feb 2011
Hi I just did a test with msi afterburner on my cpu temp in games. I7 3770k so I tested all.
CPU1 51c
cpu2 51C
CPU3 54C
CPU4 50C
CPU5 47C
CPU6 49C
CPU7 49C
CPU8 44C
I no there are only 4 core with 8 threads. Any way all 8 has a couple of degrees up or down highest any one got to was 55c only playing City Skylines. Is this an ok temp?.
Thanks.
CPU1 51c
cpu2 51C
CPU3 54C
CPU4 50C
CPU5 47C
CPU6 49C
CPU7 49C
CPU8 44C
Thanks.
Lol I used to have an i7 920 that used to idle at those temps. 6 years later its still alive and kicking albeit in another PC.
Those temps are the average for the stock coolers, if you get a after market they will drop loads. My idle temps are 22c. I had them at 18c but wanted to change some Vcore settings to get my build cooler when stressed.
