cpu temp 75-80
1 Aug 2012
one stupid question i totally forgot to put the pump power of h100i and connected the radiator fans directly to motherboard and i was running it for around 40 min when i saw the temp around 75-80. should i be worried.
No reason to worry. If it was going to do any serious harm you'd already have a dead computer.
Chances are the CPU's thermal throttling kicked in, and 75-80 isn't dangerously hot anyway.
Connect everything up correctly and keep an eye on things for a while.
Indeed no reason to worry, all modern CPUs will start to throttle when temps get to hot to protect them selves.
ohh good to know. everything is working fine but i am getting a A0 debug code instead of the cpu temp. how can i get rid of that.
thanks
