CPU temp display
4 Sep 2005
London
Hey all,
Was just wondering if there was a small app that just displays the CPU temp on screen, similar to fraps display of fps?
Thanks
<maddness> said:
now that will be cool, maybe something on all 4 corners of the screen
fps - cpu temp - gpu temp - fan speed :D
Well i've got GPU temp, fps, and case temp on screen... Just wanted cpu temp as bartons tend to get a bit hot :)
Usher said:
unless your mobo has the facility to display temps then I can't see how you could do it,
my Asus utility gives me the cpu temp & all the fan speeds & voltages
Well my Abit mobo does that.. but i want it displayed in game
with the FlashOSD settings page.
check "use FlashOSD PLugin"
select "OSD Motherboard Sensors" from the drop down menu and hit configure
From the new drop down, select what monitoring software you use and in the panel below just check the relevant sensors:)
easy
easy
Ohh thankyou :)
i found it in riva tuner has a bit in it that will display my temps of graphics card and processor in the top left corner whilst in games
which is what i wanted
i allready have software that shows temps in the taskbar
How did u get riva tuner to do this? What settings did u have to change/enable?
cheers
