I have installed an Artic cooling freezer 7 pro and now the temperatures in AMD overdrive are wrong. When i use easytune 6 the temperature reading is correct (when compared with the BIOS). The correct CPU temperature is displayed as TMPIN1. I am worried that the if i try and overclock the cpu the temperature will be incorrect on AMD overdrive and may over heat my CPU. I have the same problem with CPUID HWmoniter as it displys the same temperature as the as AMD Overdrive.
Thanks
Thanks
