CPU temp reading stuck + fans not increasing
6 Jan 2018
Having a weird issue with my temps today - noticed the CPU fans weren't increasing with the temps so I ran AIDA64 and discovered the package temp is stuck on a single value but the core temps are fluctuating as they should be
HWmonitor shows the temps as normal but AIDA doesn't and the fans aren't speeding up as they should be doing when it warms up
ANy ideas what could be causing this? I have reset CMOS and updated BIOS which hasn't worked, other than that I haven't changed anything since it was last working as it should
As a side note neither HWMonitor nor SpeedFan will detect the fans on my motherboard so I can't control them manually either
If anyone else is reading this I think I've managed to sort it out by doing a CMOS reset after updating the BIOS. Managed to squeeze another 100mhz from my CPU with the latest F9C version too so happy days.
