CPU Temp
9 Dec 2006
Right, I'm reading here that people are having heart attacks when their CPU temp reaches 68C.
I've got an AMD FX-42 (I think, possibly lower). Thats not really overclocked (MB inbuilt setting, about 5%). (I know, why buy 1 if I'm not o/cing? good question).
Anyway, I've installed Speedfan and MSI CoreCell (its an MSI Neo2 Platinum mobo). And I get a idle temperatue reading of 80C, which goes to 95C if I run 3Dmark. Can anyone explain this. The processor has a non-standard cooler I bought and AS5 between them.
Now I know I'm coming across as I right idiot here but can anyone explain this? I've had this for over a year now and apart from some random crashes which may be overheating issues its been fine. It doesn't matter a huge amount as I'm upgrading right now anyway, but I'll probably give this to my bro and would like to have a go at overclocking it as I paid a vast premium for it :)
Where should I start?
Lian Li Case with 2 120mm fans in it (1 over the Hard drives), working :).
Cooler (cant remember what it is), its got probably a 90mm fan on it (working :) ), maybe smaller.
There is no such CPU as FX-42, only FX-51/53/55/57/60/62 and the newest AMD Quad 4*4 platform that uses FX-70/72/74.
What is the cooler you are using??
Have you tried using other apps to monitor temp??
Try downloading Core Temp and see what it says.
Ah yes sorry Fx-53, I knew 42 didnt look right :).
Core Temp gives the same temp as SpeedFan. I don't think the temp reading is wrong, I'm just looking for answers as to why it is so high? I presume it is abnormal for FX-53s.
Thanks though.
