cpu temperature question
1 Jun 2014
ryzen 5 2600.
I would like some advise on cpu temperature while playing games ? I will be setting up some fan curves on my pc but wanted to know the best temp while under load to keep my pc running smooth.
ryzen 5 2600.
55 to 65 depending on what its doing, also depends on how good your cooler is, its fine up to 70c i think.
ryzen 5 2600.
I got a Ben Nevis cooler, with 2 case fans at the front and 1 at the back. Overclocked to 4.1 and the temperature is usually under 45 for regular use and gets upto 55 under more intense loads. I think anything under 65 is fine, but should need to think about better cooling options if it gets past that.
