CPU Temperature Spiking
22 Mar 2020
Brighton, UK
Does anyone elses temperature not sit at a solid number. Mine can jump up 10 degrees then slowly go back down then back up by 10 degrees and then slowly back down. Anything to be concerned about?
No reason to be concerned. There's all sorts of background processes that require a spike of CPU power, that obviously raises heat and you may even hear the fans ramp up slightly. Then when it's over, it settles back out.
If you would like to know what's causing it, though, keep an eye on processes tab in task manager and see what the culprit is.
