CPU Temperature
22 Aug 2009
Hi,
I just ran my 4GHz overclock and these were the results.
I tried to run it again and it crashed at around 92 Degrees, what temps should i be expecting?
Ignore the IBT I ran it at maximum not standard.
Im now running my default BIOS to log the temps etc and then I will do another test on the overclock.
BTW The cooler I use is a Prolimatech Megahalems but I am replacing it with a Corsair H70.
Normal results.
Temps are very high, I used the TRUE on my pc (in sig) and got around 70c ~ tops during the warmer months.
I would have a go at re-seating the cooler before purchasing another one.
Thanks for the reply RJC
I have been looking into purchasing it for a while anyway :D so I bit the bullet and hope everything turns out alright.
So I should be expecting ~70 Degrees when I have the cooler installed.
