cpu temps for 64 bit vista
14 Jan 2005
swadlincote
hi guys .
what you guys using to get the cpu temps in 64 bit vista ?
i only used to use core temp but that doesn't seem to work with 64 bit vista :)
PC Wizard temp detection is not working on Vista 64 with a Q6600 - it is just stuck on 35degrees. Ran Prime95 for a few minutes, remained on 35 degrees. CoreTemp reported 50s+
