CPU temps
15 Nov 2007
Sheffield, UK
just wondering if i seated the heat sink slightly wrong becasue one core is quite a lot higher than the other when idle. Also that one core never seems to change temprature much even when loaded. was wondering whats going on D:
idle
load
can you test the temp sensors in core temp? i cant remember as I'm using real temp. if you cant, download real temp and click on test sensor. it may be a case that one of the sensors is stuck so wont give an accurate reading. resetting the heatsink and making sure your chip is properly placed may help though. one of my cores seems to be stuck at 36degrees when the rest are in the low 30s but there appears to be a bend in my cpu cos of a misalignment :eek:
