CPU throttling/frequency problem
Caporegime
26 Aug 2003
Leafy Cheshire
Hi guys, hope one of you can help, or point me in the right direction. I've just finished building a rig based on a Gigabyte GA-X99-SOC Force motherboard, coupled to a Xeon E5-1620 v3, and 32GB of Kingston HyperX Predator (2666) RAM. For the sake of "completeness" I'm watercooled using an EK Supreme, 2x EK CoolStream 360 radiators, a XSPC Photon 270/D5 combo and I've also got my 1070 in the loop using a Heatkiller IV full-block.
Now, the problem that I'm having appears to be one of the CPU not running at full speed, or indeed anything even approaching full speed. I'm not sure if it's something to do with Turbo or similar, but the CPU will not run at anything other than 1.2GHz (100x12), and in Windows no amount of loading up the CPU does anything other than keep the vcore at 0.7v and the frequency at 100x12. When the machine boots into the BIOS it also reports 1200MHz as the current speed (though I can see that it's set to 100x35, also tried 100x36 just to see).
Intel XTU shows that the CPU is thermally throttling (which might be a red herring, as I read that some versions of XTU have a bug that can manifest itself like this). The screenshot below shows what's happening in Windows. I've got Prime95 open and running a blend across all 4 cores and all 4 hyperthreading threads. Task manager shows the CPU at 34% load, XTU shows 100% load, and CPUz shows that it's throttled to 100x12. As you can see on both realtemp and XTU, my temps are fine, and certainly nowhere near throttled.
click for full-size image
Oh, I've also tried flashing the BIOS to the latest (beta) which I know supports the CPU.
Thanks in advance.
Is there an option in the bios to setup a temperature for its throttling limit? If so maybe that is stupidly low and you have ever missed it?
Have you tried manually setting/forcing the voltage to ~ 1.25 ?
Turn off all the auto throttling and auto voltage items in BIOS.
In XTU, can you click on each of the two wrench icons and enable the other monitoring items? There are other throttling metrics called "Current limit throttling" and "Power limit throttling" which may give us more clues. Also, go to the benchmark section of XTU, it will show information about BIOS settings as well as power and current limits.
Could you also run the Intel Diagnostic Tool, please? https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool
Unfortunately guys and gals, you are all incorrect and what i previously posted is in fact the correct answer. I know this because I am sat next to him. He had already given me the answer :)
That's interesting, glad it's solved. What switch on the the motherboard were you referring to?
You created an account on a forum for him to post a question and you to give the answer seeing as you were both in the same room?
Confused.
Not quite. He posted to wind me up, as I was raging at work that I couldn't work it out. When it turned out to be an RTFM problem, well :(
Oh and for what it's worth, it was the OC_Trigger switch. It locks the CPU to its lowest multiplier so you can recover from too high an overclockers without a CLR_CMOS.
