Hi,
I have a Core 2 Duo (E6300) running at stock (1.8Ghz) with an Arcic Cooling Freezer 7 Pro, with fan on contstant full speed.
I was wondering if these temps are OK, using Intel TAT
At Idle:
CPU 0: 40 - 42 (fluctuating)
CPU 1: 39 (stable)
Full Load:
CPU 0: 55-56 (fluctuating, possibly creeping higher)
CPU 1: 53-54 (as above)
Are those temps OK? They seem a little high... Do you think I should reseat my heatsink?
I will be overclocking to approx 3ghz hopefully, so would like them to be a good temperature. What kind of temps should I be aiming for before I consider overclocking?
At Idle:
CPU 1: 39 (stable)
Full Load:
