CPU updrade?
28 Feb 2013
Leeds
Hi guys i recently purchased a Acer Aspire Ethos 8943G Gaming/Media Laptop
The CPU i Intel core i7 Q720 1.6GHZ 1st Gen.
Can i upgrade this CPU to a 2nd or 3rd gen ?
iv tried googling it but couldn't find anything.
any help/info would be great, thank you :)
You can't
Upgrading CPUs in laptops is pretty shaky anyway, due to the bios being so locked down, but the best you can usually do is to upgrade within the same CPU family - often just to CPUs which were available as an option on that model.
Looking at the socket type and TDP (45W) I think you can go up to a "Intel® Core™ i7-840QM Processor (8M Cache, 1.86 GHz)".
Anything better seems to have a 55W TDP, which could push your laptops cooling solution too hard.
Just leave it as it is, if you want to upgrade you are better off using the money to another laptop because for the amount of money on the upgrade to performance you get out of it isn't worth it.
