cpu upgade advise
13 Jan 2006
Its that time of year when i start looking for my next upgrade. I have at the moment a [email protected] this i have had now for about 10 months now (the longest ive had a cpu). Apart from a couple of problems to start with (ram) ive had no problems with it.
I was looking for some advise as to the next heart for my machine. I dont want to go down the quad route so that leaves only C2D (as i want to stay intel) and cant afford i7. Which of the E8*** series would be the best buy, i want something that will overclock well and give the best value (bang for buck). I have watercooling so heat will not be a issue.
I only want to upgrade my cpu as i happy with the rest of what i have (at the moment that is)
Thanks.
Oh yeah HAPPY CHRISTMAS. Hope santa brings all you wish for :)
Shame you don't want to go AMD as I'd suggest Deneb when it's released. RJC's suggestion looks pretty good to me though.
If you want bang for buck, then you want the E5200.
I've had the following CPU progression (also on water, so heat not an issue):
E2180 @ 3.4 Ghz
E5200 @ 3.8Ghz
E7300 @ Testing..... (suspect around 4Ghz - 4.2Ghz)
I would have kept with the E5200, but killed the E2180 I had in another machine, so used it as an excuse to upgrade and hopefully break the 4Ghz barrier :D
The E5200 is by far the best for bang for buck - it also has a nice high multi, giving you more freedom with memory.
If you want 4Ghz, then you would probably be wanting the E7300.
I don't think the 8 series is justifiable for the price (for me).
All of this is said with gaming / 3D benchmarks as the core task btw.
Nothing.
Your current CPU is plenty good enough, put any upgrade money in the bank and wait a year. Then buy a much bigger upgrade.
I wouldn't say this if you had some single core socket 939 but you have a fast, modern dual core which is overclocked. Any upgrade outside of certain pro applications represent poor value for money.
