CPU upgrade advice
26 May 2007
Hi,
I currently have the below running on Vista 32bit
Intel Core 2 Duo E6600 @ 3.1
Abit AW9D-MAX intel 975X (Socket 775)
Geil 4GB PC6400 800Mhz DDR2
HIS ATI 4870x2 GPU
Just wondering would there be much difference if i upgraded to a quad core CPU? If so which one would you recommend? Will be looking at a price range upto £200
thanks
what do you use your PC for?
unless you use programmes that use more than two cores, you won't see an improvement.
