CPU Upgrade Advice
24 Sep 2014
Hi
Looking to upgrade mid-tier PC set up.
Currently a 3060ti with Ryzen 5 2600, 8GB RAM, Gigabyte B450M DS3H matx mobo. 4K and 2nd full HD monitors.
Looking for a new CPU & mobo setup (I think the current mobo is not fully working). Would prefer DDR-4, matx and air cooling.
The newest Intel and AMD CPUs appear to be DDR-5, so was thinking of a Ryzen 7 5800x. This is a couple of years old though so is it worth the extra expense of a newer CPU?
Main uses will be gaming, general PC work.
Thanks!
The 5800x3d is one of the fastest gaming cpu's which will Drop in your motherboard with a bios update.
What's up with your motherboard?
Thanks both.
The 5800x3d is £360 at OC, the 'vanilla' 5800x is £260. Is the 5800x a decent CPU?
Noted re. the RAM.
Current mobo wired ethernet is not working, so I need a ethernet>USB adapter. GPU takes up the PCI slot so I can't squeeze in a PCI ethernet card. Also I think the GPU slot is not working properly, performance has dropped off.
Thanks both.
Noted re. the RAM.
Read reviews on the 5800x3d which is on par with the latest 7600x but the 5800x is good value.
The 5600 6 core is stonking value at £140 along with a b550 motherboard and 16gb or 32gb memory would bring your pc up to date.
Selling your old parts should help fund your upgrade.
