CPU upgrade advice
6 Nov 2002
So I'm looking to replace my current audio PC that use to run Cakewalk/Ableton etc. At the moment I have an old Dell with an i5-6500 and 16gb RAM which is wheezing at the amount of synths I'm trying to run on it.
I have a budget around 450 and having looked around, I'm thinking either a new system with a Ryzen 5700G or something second hand with a Ryzen 3900x and the cheapest gfx card I can find.
Any idea how these two would stack up against each other for audio based workloads? I'm assuming either would be a decent step up from my current PC?
(I don't know anything about those particular programs, or the needs of audio work, so I'm replying more generally)
The 3900X is generally faster in productivity apps (in e.g. Blender, by quite a lot), but in something that is more single core/thread heavy like Photoshop then the 5700G wins, though it doesn't win against the 5600 non-X or 5600X (in many scenarios that single core/thread matters) as much as you might expect, because of the loss of cache.
If you want to avoid buying a graphics card then the 5700G isn't a bad choice, you could also get a 12400 (not -F) for similar money and hopefully a 13400 (with the addition of 4 e-cores) sometime next year.
Against the 6500, both would be a big jump in raw CPU performance, since they (the 3900X and 5700G) have faster cores and at least twice as many (the 12400 has 6).
Intel Core i5-12400 2.50GHz (Alder Lake) Socket LGA1700 Processor - Retail - £229.99
Asus Prime H610M-A D4 - Intel H610 DDR4 Micro ATX Motherboard - £110.99
Team Group Vulcan Z T-Force 32GB (2x16GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit - Grey - £99.95
Grand Total: £451.43
(You can get a 12500, or maybe even a 12600 for the same money, by the way and there some big deals on the 12600K and KF not long ago, which might be back on black friday)
