CPU Upgrade Dilema
14 Sep 2006
Dorset Apple Cake
I need some help guys.
I currently have a Pentium D 930 that has been running very stable for months
@ 3.6Ghz 240FSB, 4mb Cache
This chip is the presler 65nm and sits idle @ 41c and 56c under stress sat under an Akasa AK-961 cooler.
I have benchmarked the cpu on pcmark 05 and got scores of 6000 which is not far off the E6400 at stock.
The dilema I am in, is that would it be really worth it buying an E6400?
Am I better to upgrade the RAM or even the Graphics Card?
I have a £200 birthday budget.
I use my pc for some video encoding, gaming and general internet usage. I also like to dabble with some overclocking too.
Other specs are:
P5N-E SLI
2Gb Samsung 533@640
Nvidia 7900GS
Any comments will be appreciated
q6600 would do it sell your cpu and add another 2gb 533 ballistix should have you all nice and sorted m8
Other specs are:
P5N-E SLI
2Gb Samsung 533@640
Nvidia 7900GS
£200-00 will get you a E6750 and a P35 motherboard, plus you could then sell your current setup as a unit (known tested working ...)
http://www.overclockers.co.uk/showproduct.php?prodid=MB-129-AB&groupid=701&catid=5&subcat=913
http://www.overclockers.co.uk/showproduct.php?prodid=CP-157-IN&groupid=701&catid=6&subcat=
In an ideal world of course you could get some 667DDR2 to go with that.
