- 27 Dec 2002
- Beyond the Ultraworld...
I currently have a 3.2 P4 with 2GB of DDR2 667 RAM and an Abit IL9 Pro motherboard and was looking to upgrade my CPU without having to buy other components if possible.
The motherboard itself has a CPU Support List which suggests that the fastest CPU it will take is the Core 2 Duo E6700 but I take it if I wanted that I would need to purchase some new RAM to match its speed. Is this correct?
If I need to upgrade me RAM I think I will go for the 800mhz Core 2 Duo E4500 instead as that is the highest chip that I think my memory will allow.
Does anyone have any experience of any of these chips and if I were to go down the E4500 route will I notice a major difference in general Windows use and extracting rars etc compared to my 3.2 P4 chip?
Finally, will I be able to use my current heatsink (see sig) with the dual core CPUs?
Thanks in advance.
Thanks in advance.
