- 25 Mar 2006
- Thornbury
i have an old advent 7000 which has a 1.3 celeron cpu, i decided to upgrade the cpu and memory, i bought a second hand cpu INTEL PENTIUM M 1.7Ghz CPU 400MHz SL6N5 off an auction site FOR £6, i installed it to the laptop with a little heatsink paste used, the laptop boots into windows xp fine and works ok i can open my computer etc and its a bit snappier than it was however after 5mins of use the laptop freezes and i have to hold the power button to shut it down.
does this sound like a faulty cpu or is it possible the cpu wont work with this laptop ? ill mention i have not upgraded the ram yet so its nothing to do with that.
LAPTOP SPEC
LAPTOP SPEC
