CPU Upgrade Question
11 Apr 2003
Notts
Well i curently have a Barton 2500+ M, clocked to 2.41Ghz, with a 200FSB, but im looking at building a new pc with a X2 4800+ In.... i notice this runs at 2.4Ghz and i was just wandering how much difference its actualy going to make..... Same clocks speed after all :confused:
Building a system with an X2 4800 will be a HUGE difference to your xp2500.
Much more powerful and faster in general use and load use... i.e. gaming or intense applications
Well that sounds good then, especialy considering that come september i will be using it for graphics design :o
Bigger cache 2mb on the x2
Different architecture and there is two of em under the hood as its dual core!
No need to compare, the x2 slaps the xp2500 around the face a bit.Teases it then eats it for breakfast.
Hope this helps! :D
