- 24 Feb 2004
- Leeds/Cyprus
I'm currently on a piddly little E2180, but it's clocking reasonably well, got it running at 3.2GHz atm. It's served me reasonably well, a loyal little hamster with a surprisingly brutal eye-gouging bite
However, I've just bought a GTX260 from someone at the MM, and I figure that with the E2180 I'll be CPU limited, so I'm thinking of upgrading. I don't want a new motherboard just yet, and my P35-based clunker won't take any of the fancy new i5s or i7s etc.
So, I'm looking through its compatibility list, thinking what can I upgrade to. Since the point of the upgrade is gaming, I'm not seriously looking at the quad cores, since I doubt any of the games I play would thread very efficiently. But, on the other hand, most of the dual cores I can upgrade to are about the same speed as my overclocked E2180 is running at now! Sure, the bigger cache will give a bit of a boost, but would that amount to anything more than, say, 5FPS? I doubt it.
Is there a decent CPU upgrade path open to me, one that won't cost the earth and will deliver a noticeable speed boost, or will I have to wait until I'm ready to get a new mobo?
