- 1 May 2003
- Blackpool Lancs
Having just bought 4gig of ram and an 8800 gtx im not sure if the board has to go next.. currently running a gigbyte 965p ds3 with an older presler cpu at 3.4ghz...
Im told (correct if wrong the current penryn quad will work ok with it?
Is it worth going Intel Core 2 Quad Pro Q6600 "Energy Efficient SLACR 95W Edition" 2.40GHz (1066FSB) for thr 160ish quid?
and will it run ok? big difference?
Specs of full setup below and any comments welcomed
Number of processors 1
Number of cores 2 per processor
Number of threads 2 per processor
Name Intel Pentium D 945
Code Name Presler
Specification Intel(R) Pentium(R) D CPU 3.40GHz
Package Socket 775 LGA
Family/Model/Stepping F.6.4
Extended Family/Model F.6
Core Stepping C1
Technology 65 nm
Core Speed 3417.0 MHz
Multiplier x Bus speed 17.0 x 201.0 MHz
Rated Bus speed 804.0 MHz
Stock frequency 3400 MHz
Instruction sets MMX, SSE, SSE2, SSE3, EM64T
L1 Data cache (per processor) 2 x 16 KBytes, 8-way set associative, 64-byte line size
Trace cache (per processor) 2 x 12 Kuops, 8-way set associative
L2 cache (per processor) 2 x 2048 KBytes, 8-way set associative, 64-byte line size
Chipset & Memory
Northbridge Intel P965/G965 rev. C2
Southbridge Intel 82801HB/HR (ICH8/R) rev. 02
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR2
Memory Size 4096 MBytes
Memory Frequency 402.0 MHz (1:2)
CAS# Latency (tCL) 6.0 clocks
RAS# to CAS# (tRCD) 6 clocks
RAS# Precharge (tRP) 6 clocks
Cycle Time (tRAS) 18 clocks
Command Rate (CR) 2T
System
System Manufacturer
System Name
System S/N
Mainboard Vendor Gigabyte Technology Co., Ltd.
Mainboard Model 965P-DS3
BIOS Vendor Award Software International, Inc.
BIOS Version F4
BIOS Date 08/11/2006
Memory SPD
Module 1 DDR2, PC2-6400 (400 MHz), 2048 MBytes, OCZ
Module 2 DDR2, PC2-6400 (400 MHz), 2048 MBytes, OCZ
Software
Windows Version Microsoft Windows Vista (6.0) Ultimate Edition (Build 6000)
DirectX Version 10.0
btw is a pure games / fun pc...
Code Name Presler
Core Stepping C1
Technology 65 nm
Chipset & Memory
Memory Type DDR2
System
System Manufacturer
System Name
System S/N
BIOS Version F4
Memory SPD
Software
