CPU Upgrade!
16 Oct 2005
Poole
Hey guys i currently have an overclocked E6600 @3.02ghz and i need a decent upgrade for my gaming needs! My other main specs are Windows 7 64bit, 4gb RAM, ATI 4870 1gig. The cheaper the better for this upgrade as im off on holiday in 2 weeks so trying to keep spending to a minimum :)
What resolution do you game at?
It's almost certainly not worth upgrading for games if you're gaming at 1920x1200 for example.
If you just want a new CPU to play with, that's different, but if you're upgrading to improve your FPS, I think you'll be disappointed.
Take a look at games performance in Dirt2 @ 1600x1200 for example:
http://www.techreport.com/articles.x/18581/7
i7-980X = 74 FPS and £800
Core2 E8600 = 62 FPS and £129 (this is roughly equivalent to your overclocked chip)
In Left4Dead @ 1600x1200:
http://www.techreport.com/articles.x/18581/9
i7-980X = 97 FPS
Core2 E8600 = 97 FPS
As you can see from my sig, I'm huge believer in spending twice the cost of the CPU on the GPU.
In short - my recommendation is to get a new GPU if you want better performance in games.
The 4870 isn't bad - and some games do prefer quad (won't bother to list them though). But depending on the games, yeah, a new card such as the 460 could be worth it.
i7-980X = 97 FPS
I thought you need i7 920/30 @ 4.2ghz for gaming, that's what someone on those forums says. The benchmarks must be fake ! ;-)
AW9D-MAX.
I game at 1680x1050.
Q6600 is definitely the chip to go for although the AW9D Max was/is notorious for clocking quads as the 975x chipset usually struggles with FSB past 310/20. You might be lucky though! If you go down this route make sure you flash to the latest BIOS v17.
This board handles duals fine and you will hit 400+ FSB on it. I ran my e2160 at 8 x 425 successfully until recently.
Why mess around with the CPU when you *should* ditch your 4870 'now' and buy a GTX 460 ?
Well im buying a new system just before christmas and was looking for one last little upgrade to squeeze the last bit of juice out of my currant ageing build! And as far as I can tell the biggest bottleneck is the CPU.
