hi, i have a athlon 64 x 2 duel core processer 3800+, 2.0ghz. What is the best upgrade to do with the same motherboard.
I want to play BC2 and NFS Unleashed but its juddery. Can you help please?
My pc spec
OS windows xp sp3
Processor:athlon 64 x 2 duel core processer 3800+, 2.0ghz
Memory: 4GB
Hard Drive Space: 260 GB
DVD Drive: 8 SPEED
Graphics Card: Nvidia GForce8400gs 512 mb
Minimum System Requirements:
OS: Windows XP (SP3) / Vista (SP2) / Windows 7
Processor: Intel Core™2 Duo 2.0 GHz / AMD X2 64 2.4GHz
Memory: 2.0 GB
Hard Drive Space: 7 GB
DVD Drive: 8 SPEED
Graphics Card: DirectX 9.0c Compatible 3D-accelerated 512 MB video card with Shader Model 3.0 or higher
My pc spec
OS windows xp sp3
Memory: 4GB
DVD Drive: 8 SPEED
Memory: 2.0 GB
DVD Drive: 8 SPEED
