Boost frequencies.
I don't think i3 got boost until 9th gen.Boost frequencies.
its a work computer lolrun taskman and see what's using those processes.
221 lol what a bloaty mess is that fresh boot? Mine is <90
You're right. Then I have no explanation...I don't think i3 got boost until 9th gen.
Lots of stuff running since it's a work pc so won't be idle. Dual core CPU so gets a beatingIf it's in Windows idle, everything closed it shouldn't be doing that. Sort by CPU usage and see what's at 100%
How did you get down to <90, curious to see what you removed, disabled etc safely without causing issuesrun taskman and see what's using those processes.
Get a new tech guyTop tech guy at work saying it shows 4 cores and it's using 100% of 1 core and 5% of another core.
What are your thoughts on this?
