The only two things that I changed were intalling a new gpu , which it was working great, then on christmas day I installed a new exhaust fan and put my monitors on a stand.What's changed since the last time you ran the benchmark? I'm assuming you're not running it for no reason, but that you've made a hardware/configuration change or have noticed a drop in game performance.
Can you get MSI afterburner or your GPU monitoring/tweaking software of choice and look at what the GPU core/member.php speeds are during load?
At 1920x1080 and depending on your CPU and GPU, more information can be processed by the CPU this could be the case if the CPU you have is a slow CPU. When teting this on an AMD APU A10 7850k compared to an Intel I3 with a 960 and 980 GPU the CPU untilisation was a lot higher on the AMD than on the CPU and my score was about 1000 - 1200 points more on the I3 than the A10 7850K. This was also running at 1920x1080.
If this was running better before i would check the temp of the CPU and make sure that is not throttling, like wise for the GPU. Somthing like HWInfo can help check your sensors on your system and show what tempratures you are getting. also GPUz can help with sensor information on your GPU.
Are you getting any instability with the system?
The fan was plugged into the pwm hub. I have since taken the fan back out trying to problem solve.I think he means he posted under wrong name on here.
When you did the changes.. Was it previously plugged into the gfx card and now is in mobo? Wondering if you're just running iGPU now for some reason.
Set card back to factory settings and update driver?
That's a all I can think of, it's a weird one.
Try some other graphics benchmarks, same issue?
The monitors have always been plugged into to gpu.I meant where were the monitors plugged in before/after? Apologies, wasn't at all clear!
