Ok, you'll need to go to your BIOS. Your CPU Core voltage mode is probably set to manual mode. You need to set that to offset mode, then set the offset voltage as positive then enter 0.02. That should work.
Ok Set where the red arrow is to "Offset mode" and the yellow arrow to 0.02. It should also ask if you want a positive or negative offset, you want a positive offset.
