Hi,
I'm trying to overclock my Q6600 G0 to around 3.4-3.6. I have a 1.3250v VID chip which isn't great, but I've got a decent cooler and a good case with loads of fans, so temperatures aren't too much of an issue at the moment.
However, i think a possible cause to my problems is the fact that the CPU voltage i set in the BIOS doesn't actually show up in Windows. It's set at the moment to 1.4250v, but software is reporting it as 1.40v, which when overclocking is quite a gap.
Which do i believe?
Is there anything in the BIOS (P5Q Pro) i can change?
Thanks.
*Speedstep and C1E are disabled also.
Which do i believe?
Thanks.
