CPU volts fluctuating in cpuz, is it normal?
24 Oct 2005
North East
Bit worried as its 1.4 in bios but in cpuz its ranmly going fgrom 1.390 ish to 1.44 ish. Im a bit worried is it ok or if not how do i stable it out to 1.4 all the time?
Asus a8v deluxe rev 2 motherboard
Amd 64 3500+ cpu
asus v9999GE card (6800 2 power connectors)
Audigy 2 ZS
dvdrw
2gb GEIL ddr400 ram
arctic freezer 64 pro
1 led 120mm fan blowing at back
Akasa paxpower 400w psu
Bought recently, should be powerful enough.
On the othe comp i had befdore building this the amd xp 1900+ was rock stable volts at 1.75 so just woundering why its like this on this new comp.
does it on mine too and its perfectly stable.
probably something to do with draw on your 12v lines, they do fluctuate based on load.
as long as 3.3v 5v and 12v are as near as these values as possible your fine voltage will always fluctuate nothing to worry about
cpu-z does not give you totally accurate readings, it rounds the value up or down. If your voltage lies in the middle of 2 values then you will see it 'fluctuating'.
If possible, try putting a multi-meter across a molex plug to test 5V/12V and I'm confident that it'll be stable :)
CPU-Z says that my cpu is only drawing 0.769v so i take what it says with a pinch of salt.
Yes cool and quiet is disabled and that was overclocked to 2.645ghz with 1.6v going through it.
