Hi all,
I recently bought a PC (2 months old!!) which had an "Eco CoolIT" CPU cooler. The thing (pump) started making rattling sounds so I was sending in an RMA e-mail to overclockers about it; anticipating that it would die on me in the coming week.
Hours after sending the e-mail, the pump explodes (i hear it pop and stop running) and it starts pumping all the fluid out...
I set up a CPU heat monitor before hand, and set it to warn on 55 degrees in case the pump did fail on me. I didn't antipate it to explode and leak on me though... I alt-tabbed to my cpu monitor and watched the temp rise from say to 48 to 51 and as i was about to turn the computer off it crashed (screen froze).
what is the chance of permanent damage? The screen only froze. The motherboard was completely covered in liquid and it looks like the PSU narrowly avoided any contact.
im actually getting some dionised water to clean the motherboard with properly... Does anyone have experience in this?
Pretty ****ed off with the eco coolit right now. The pump failing I can uderstand but popping and forcing a leak? gtfo -_-;;
. You should have cut power to everything the moment you saw a leak though...turn the psu off, yank the plug out.
